They appear in the order they were put in - sure - but they aren't associated with a point unless you manually key the point number in first on site...
Right click a note in the "imported files" tree in TBC and click properties, it doesn't have any associated metadata except what you might key in onsite. Other survey processing software takes "keyed in" notes (CTRL N) from Access and automatically associates them with the previously collected point - from which the note can then be placed next to the point in the processed survey for further convenient use. I realise there are other ways to record data e.g description attributes, but often you just want to write something manually onsite unlimited characters and have it associated with a point!
Like others I can't understand why such simple obvious thing is not standard in the software already... as Carsten says mentioned a year ago but nothing in the 3 or 4 versions released since....
Please tell me I'm wrong and it's possible in TBC somehow currently! If so please spill!
