Currently when placing text against a point, for example, we seem to only be able to put either all attributes against that point or none. There appears to be no way to select just a specific attribute for placing text, which would make sense as many users would want to collect more attributes in the digital form than show in a printed result.
This is important for things like Trees, where if a tree was picked up from a scan using the Extract Point Feature tool, we are able to map trunk, spread and height (amongst others). When a user goes to place text on a tree collected using this method for just the height, they don't seem to be able to as TBC only lets them place all or nothing.
If I am missing a setting here sorry, happy to climb down from my soapbox if someone has a simple (there are other more complex workarounds in TBC) method for doing this!
