Brice - It's not possible to directly export the drill plan as a CSV, but it is possible with an extra step. From Project Explorer, right click on drill plan and select "Generate Design Points". If this is a VCL drill plan, this will create CAD points for each holes at various locations:
-Rock surface intersection (if rock surface was referenced when building drill plan)
-Design surface intersection (where hole intersects with referenced design surface)
-End point point (bottom of hole coordinate that will be different than design surface point if subdrilling was used)*
*If using an IREDES .xml drill plan, only the end point will be created when using this command.
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/JiveInlineImages/142958.png)
