Closed Linestring Figure Start Points
  • 1.  Closed Linestring Figure Start Points
    Posted 10-02-2019 15:51
    Due to the way the stringless slipform curb machine needs to look ahead to start it's turn to extrude curb through tight radius, such as "hotdog islands", the linestings can not start at a PC/PT. Otherwise, when you get to the end of the linestring, the machine won't know about the upcoming radius and your basically stuck. And, as you can probably guess, 9 out of 10 times, the figures in the engineers CAD files start at the PC/PT's. Simply breaking the tangent section of one side and rejoining usually joins the figure as it was prior with the start point at the pc/pt. To overcome this, I go through the following process. I'm hoping there is a "less steppy" way to get the start point moved. Any suggestions will be greatly appreciated.
    1: break one of the tangent sides at the mid point.
    2: use the cad grip to separate the sections at the break point.
    3: rejoin the separate sections
    4: use the cad grip with end snap to realign the tangent side halves.
    BREAK AND SEPERATE AT MIDPOINT OF TANGENT SECTION
    REJOIN PIECES
    CLOSE GAP WITH CAD GRIP
    NEW START POINT NOT A PC/PT
    I don't know what goes on during the .svl export process, but for other reasons we've had the line string start/stop/break at the pc/pt resulting in basically having to skip the radius and hand form at that location. Moving the start point as shown above hasn't failed us as of yet, thus is why we do this every time.
  • 2.  Re: Closed Linestring Figure Start Points
    Posted 10-17-2019 13:06
    Buller, Buller, anybody?
  • 3.  Re: Closed Linestring Figure Start Points
    Posted 10-18-2019 04:45
    Something like this may make this process easier for you: Feature Request - Quick move of start and stop for a closed polyline
  • 4.  Re: Closed Linestring Figure Start Points
    Posted 10-22-2019 03:53
    What if you use the "break" command on the polyline at the point where you want the new start? And afterwards you "join" the two lines back together. I just did a quick test and it did as I was expecting.
  • 5.  Re: Closed Linestring Figure Start Points
    Posted 10-22-2019 06:59
    Thanks Ronnie - I usually use the Base Line / Line to Join method which usually joins them as they originally were. I see you are using the Join all selected line method which is giving the desired results. I will definitely try that next time. Thanks again. I figured it was something simple I was missing.
