Create DYNAVIEW issue with Cut/Fill Grid [5.30]
  • 1.  Create DYNAVIEW issue with Cut/Fill Grid [5.30]
    Posted 05-05-2020 16:07
    So I spent a couple of hours trying to figure out why I could not get a Cut/Fill Map DynaView to draw in a Sheet View. Have done them probably 100 times without issues. I did tests in new files and was having no problem getting one to draw with basic figures. Then by happenstance, I turned off the layer that contained the Cut/Fill Grid info and BAMN! the DynaView appeared. Turned the layer back on and the DynaView content disappears. So it appears that there is a defect that needs attention. Let me know if you need my data to reproduce and resolve.
    CUT FILL GRID LAYER ON
    CUT FILL GRID LAYER OFF
  • 2.  Re: Create DYNAVIEW issue with Cut/Fill Grid [5.30]
    Posted 05-11-2020 13:39
    As discussed this am Richard - this is caused by the Legend that you have on the layer in question that points at a Cut Fill Map that has been deleted, and the legend has its Display Ares setting set to No. If I change the Setting to Yes or Delete the legend the issue is cleared and all works well.
    This is a real corner case defect - and has been logged in to the system - but the solution is a good one I think - the defect should not of course exist and we will strive to address it.
  • 3.  Re: Create DYNAVIEW issue with Cut/Fill Grid [5.30]
    Posted 05-11-2020 13:42
    I deleted the orphaned legend as suggested and the DynaView worked as expected.
    Thank you.
