Publish Field Data to Project Library - Check/UnCheck
  • 1.  Publish Field Data to Project Library - Check/UnCheck
    Posted 08-04-2020 12:53
    I have one out of 36 pre-selected file to publish. So now I need to uncheck 35 pre-selected files to publish one file. The other day I had to uncheck 96 pre-selected files, to publish (wait for it) one file. Do you think we can get a select all / de-select all check box at the top of the list please? Thanks.
  • 2.  Re: Publish Field Data to Project Library - Check/UnCheck
    Posted 08-08-2020 05:31
    bump...
    How about it @Sanjeev Saha, can we get this obvious development omission squared away in a reasonable amount of time (i.e. with the next patch)? I know dev was made aware of it in early spring and I was expecting this to be cleaned up for the 5.31 release, but alas it wasn't.
