Publish Field Data to Project Library
  • 1.  Publish Field Data to Project Library
    Posted 09-03-2020 14:37
    Can we please get "Select All" "Select None" buttons on the dialogue box similar to whats shown below........please.
    Thank you for the consideration.
  • 2.  Re: Publish Field Data to Project Library
    Posted 09-08-2020 15:50
    Thanks for this good idea, Richard. I submitted it to the TBC Product Team's enhancement list.
    David
  • 3.  Re: Publish Field Data to Project Library
    Posted 09-09-2020 12:36
    Thanks David
  • 4.  Re: Publish Field Data to Project Library
    Posted 09-08-2020 16:12
    You should be able to multi-select all the designs. Just click on the first design (the text, not the checkbox), and then scroll down to the last design. Hold shift key down while clicking on last design (again, the text not the checkbox). The "selected" designs will be highlighted in blue. When you click on a checkbox all designs will toggle.
  • 5.  Re: Publish Field Data to Project Library
    Posted 09-09-2020 12:37
    Thanks Gary.... I think I tried that (probably clicked the check box though) but I'll give it another go and report back.
  • 6.  Re: Publish Field Data to Project Library
    Posted 09-14-2020 08:00
    Sorry Gary - did not function for me as you described. I selected the first design (text area), pressed and held shift key, selected last design (text area), selection highlight moved to last design and did not select the whole list.  Please consider the button suggestion. Thanks
  • 7.  Re: Publish Field Data to Project Library
    Posted 10-15-2020 12:44
    Shift doesn't work for me either. I had red this post a while ago and just went to try it. I circled back and read the update....so disappointed. Its the little things in Life
  • 8.  Re: Publish Field Data to Project Library
    Posted 09-14-2020 12:46
    Hi Richard -- I have added this to the product backlog. Thank you for sharing this with the team.
    Best
  • 9.  RE: Re: Publish Field Data to Project Library
    Posted 01-06-2021 16:06
    Just had the opportunity to use this command. Thank you for fixing it.
    Richard Tyndall
