I want to export my project as SVD/SVL files for machine control. With TBC 5.20 it worked well. Now I had to edit some little things with TBC 5.30 and the export is not working any more. I get this error:
"The high and right values in design are not valid for the coordinate system." (Thanks, Google)
What is the problem here?
Workaround: I used the export for Earthworks and unzipped the DSZ-file.
