Trimble Identity Login with TBC not is working
  • 1.  Trimble Identity Login with TBC not is working
    Posted 09-14-2020 02:27
    My colleague cannot log into Trimble Identity in TBC 5.32. If he clicks on the symbol in the menu at the top right, no login window appears. It also doesn't work if he goes into the options and clicks on login-button.
    Update: We completely uninstalled TBC and used the cleanup tool, without success.
    Does anyone have an idea?
  • 2.  Re: Trimble Identity Login with TBC not is working
    Posted 09-23-2020 06:07
    Bump!
    @Rui Wu
  • 3.  Re: Trimble Identity Login with TBC not is working
    Posted 09-23-2020 16:05
    Hi Titus and @Tobbe Hellberg,
    I just tried the sign in workflow with TBC 5.32.1 and everything works as expected, but @Adam Hussein mentioned that you're not the only user seeing it, and he has a workaround. I'll let him explain it in details.
    Thank you.
    Rui
  • 4.  Re: Trimble Identity Login with TBC not is working
    Posted 09-30-2020 22:50
    Hello Rui,
    we are still waiting for the workaround.
    Thanks for your help.
    Titus
  • 5.  Re: Trimble Identity Login with TBC not is working
    Posted 10-01-2020 13:47
    @Titus Emanuel when users cleared their cache under "%USERPROFILE%\AppData\Local\IsolatedStorage", they are able to log-in again.
    Before performing this work around can you give us the following information so that we can try to address this isue?
    - Operating system version
    - Previous TBC version
    - Current TBC version
    - How did they upgrade TBC?
    - Was the issue observed after the upgrade immediately? or after re-login TID?
  • 6.  Re: Trimble Identity Login with TBC not is working
    Posted 10-02-2020 06:34
    That did the trick. Thanks.
  • 7.  Re: Trimble Identity Login with TBC not is working
    Posted 10-06-2020 02:55
    Hey Adam, thanks for this workaround, it solved the problem.
    TBC is running with Windows 10, previous TBC was 5.31, current is 5.32, the upgrade was done online and the issue was observed immediately.
    Titus
