I agree with you Cameron that would be a great feature to be able to have standard templates stored/comes with the installation of TBC that are according to where you’re working in the world. Because the DOTs of the world usually have a handful of standard templates they use when they do designs, I’m guessing right now and referring to where I work (Sweden). It would then also be nice with a small thumbnail also so you could get a preview of what the template looks like, right?
Anyways to your question, right now you could save your template as a xml file but if you associate your template to a surface/surfaces and then import this xml file in a different project then you’ll probably get error messages. The solution would be to reference the correct surface in this new project or rename the surface to match the templates.
