Cameron
The Geospatial Team would recommend one of two workflows for Road Staking
in Access - those being
1) RXL Format Files
2) GENIO / Trimble Access Strings
The second option is for markets where the Bentley MX Software is heavily
used (UK, Australia, Middle East etc.) or a similar product to MX (12D)
from Australia. While any linestrings / alignment can be exported to a
Trimble Access Strings / GENIO file, the naming convention of MX is a 4
character name for all strings like K001 = Kerb, V001 = Verge, PLP (Point
String of Light Poles), PTR (Point String of Trees) etc. If you have fuller
names they currently get converted to a random name / string number (not
truncated to 4 characters), although there is a fix to the Formatter that
allows the string names to now be truncated to 4 characters (but that can
have the effect of making meaningful string names less meaningful etc.
The RXL Format is under review, the Geospatial team are looking at ways to
make that better for the future, however currently if you take a "Good
Corridor Model in TBC" and select output to RXL (which is a similar format
to the old DC Roads File) then TBC basically slices up the model into Cross
Sectons, and then uses a user defined tolerance value to check all of the
cross sections created to see where one cross section differs
"significantly" from the prior / subsequent sections to determine which
ones it can "throw out" and which ones it has to keep (for the integrity of
the Road Model). The Road Model will be much larger after output than the
source model data as a result, and you can have hundreds if not thousands
of Templates in the RXL file.
In the output of RXL process, there are some options as to how you want to
handle the sideslope elements - I believe you can use the last segment Left
and Right of the HAL as the sideslope or you can define a single default
sideslope value e.g. 3:1 for Cut or Fill conditions that will get added to
the corridor RXL output. These sideslope elements can be extended /
shortened in the field so that you can find the Daylight Points on the
existing terrain etc. I believe that you can also change the slope value on
those elements in Access, if you find e..g that Daylight is outside of the
ROW line and you need to change to a different slope for specific locations
along the alignment.
It has been a long time since I used Survey Controller / Access in a
production mode, so I may be slightly off on my comments above, I have been
involved with SCS900 since 2003 (when we started the product) and I have
really not tracked Access / Survey Controller in detail since that time. We
elected Terramodel PRO Files as our Roading Format because it is a much
stronger Road Model than DC / RXL files for complex road work. We use the
Terramodel Toolpack Engine as the Road Computation engine in SCS900 /
Siteworks so that we get full compatiblity on that data type in the field.
If you need me to map through the Export of RXL Files for Access I can try
to do that next week for you - however Access is a little out of my
specific wheelhouse, but I am sure that I can get with someone from
Geospatial to assist as needed
When exporting the RXL File, you should use a tight interval of e.g. 1' or
2' and put in the tolerance that you are prepared to accept as an error
e.g. .01' so that it generates a lot of sections and then weeds out where
it doesn't need the extra sections because "nothing is changing". Bear in
mind that where you have elements widening or super elevating and where you
have Vertical Curves / horizontal curves you will need more data (like
densificaton of a corridor surface model in TBC) but in long straight
sections where the slopes and widths of elements are constant you need less
data. If you however start off with 10' or 20' intervals, you immediately
introduce unacceptable errors into the model output (unless you only intend
to stake and check at those specific locations - in which case you would be
OK). The only ? I have is on the Sideslope elements and whether or not the
source model in TBC should have those or not - if you have constant Cut or
Fill Slopes along the road, then you may be better off not having
Sideslopes in the TBC model and just add them to the RXL outputs. If you
have complex sideslopes / multi element sideslopes or sideslopes where the
slope is varying along the highway, then you will need the sideslopes in
the model output to RXL format.
I am happy to try to assist you get the correct workflows - you can import
an RXL file back into TBC to see what you get back - you can build a
surface from it and then build a CF Map to see what errors are introduced -
however I am not sure how Access computes between sections - whether it
creates a surface TIN and slices that, or whether it linearly interpolates
between nodes between sections - that would be a question for the
Geospatial folks to answer.
Hope this helps
On Thu, Mar 14, 2019 at 11:21 AM ctomkins@kapurinc.com <trimble@jiveon.com>
