I would like to know if there is an option for the VAL to inherit the given STA on the HAL without having to move it.
Ex.If I use an elevated line and use 100+00 as my starting STA.... the vertical alignment tab reads 0+00 for the start then you have to open a profile view and move the VAL from 0+00 to 100+00.
If this is not an option will this be coming down the pipeline in an upcoming version?
