@Layne Meylain, this is an issue I have had to deal with myself. My local (NY) DOT uses standardized layer naming conventions. They have an excel spreadsheet with over 8,000 layers detailed. I wanted to create a .layer file with all those layers in it with the layer groups assigned and linestyle, color, etc. So when I import one of their CAD files the layers already exist in my project and all the data goes onto the existing layers with the correct colors, groups, etc. Its a bit of a detailed process that probably isn't for the beginner user, but I can get you started in the right direction by letting you know that if you download "Microsoft Visual Studio" you can use that to open, edit, and save a .xml file or a .layer file. If you use TBC to create a .layer file with a few layers setup in it and then open that in Visual Studio, you can use it as a template for how to setup your custom file. Get some good alcohol and enjoy!
