Create from CAD issues
  • 1.  Create from CAD issues
    Posted 02-07-2020 13:30
      |   view attached
    I am creating cross sections from PDF.  I ran the create from CAD command and the cross section came in(see attachment).  Any suggestions as to why part came in correct and the top layers did not?  Thanks.
    Dwayne
  • 2.  Re: Create from CAD issues
    Posted 02-08-2020 13:48
    I would have to see the data - it is probably that the linework for the sections is above or below the min max limits of the sectionn grids  (if the vertical axis of the grid is shorter than the highest or lowest grid axis point) then they will not process- depending on the sections you could either extend the grid axis lines or you can try entering a larger text to Grid distance as that has the effect of increasing the size f the search box in which we find the data to convert - dont make it so large that it will catch data in an adjacent section - but that will sometimes work - if you need me to take a look send me the data / vice file and I can take a look for you - alan_sharp@rockpilesutions.com
