Getting error when trying to export .svd
  • 1.  Getting error when trying to export .svd
    Posted 08-24-2020 12:14
    Running v5.31 I am getting an error when trying to export using Machine Job Site Design Exporter.
    Seems to be an issue with exporting surface, since I can export linework only using Machine Site Map exporter.  I tried importing .dxf and .ttm into clean TBC file and get same error.  I am using v5.31 and when I sent same .dxf and .ttm to co-worker also running v5.31 they were able to export .svl and .svd OK?
    Please note that I am getting same error when trying to create .svd using Construction Data.
  • 2.  Re: Getting error when trying to export .svd
    Posted 08-25-2020 06:02
    Ruth
    Can you share the project with me. I would also need to know what type of GCS900 Machine (Version Number of the GCS900 you are trying to export to) so that I can initially replicate the problem and try to find the solution for you.
  • 3.  Re: Getting error when trying to export .svd
    Posted 08-25-2020 06:11
    Hi Alan,
    I need to add to my post on the Community, late yesterday I had gotten a reply back from Trimble Support, thru our local Sitech, that the my issue could be an issue w/ coordinate manager. I updated Coordinate manager and that seems to have taken care of the issue.
    Thank you for taking the time to look into this.
    Ruth
