Layer name "00" from an imported CAD file caused issues, are there any other layer names that can do the same?
  • 1.  Layer name "00" from an imported CAD file caused issues, are there any other layer names that can do the same?
    Posted 05-11-2018 11:51
    Looking for layer names that may be unrecognizable.
  • 2.  Re: Layer name "00" from an imported CAD file caused issues, are there any other layer names that can do the same?
    Posted 05-11-2018 13:50
    Hi Mike,
    We are sorry this has inconvenienced you. This is a known issue that will be fixed by an upcoming patch. The problem occurs when imported layer names are considered duplicates due to leading zeros being ignored, e.g., layer name "OG01contours" is seen as the same as "OG001contours". The simple work around is to vary either the numeral or the alpha prefix or suffix in the layer name either before the step that throws the error.
    David
  • 3.  Re: Layer name "00" from an imported CAD file caused issues, are there any other layer names that can do the same?
    Posted 06-04-2018 07:44
    This was corrected in the 4.11 patch.
