Since I installed v5.21 I have a problem when I create a Job Site Design. After select a surface, stakeout points and design map, going in the new folder created by TBC (Trimble SCS900data-->Site-->Designs-->Created folder) no file is save or display, the folder is empty (no ttm,csv or dxf files). If I create a new work order a crash window compare and no work order is created. Anyone has same problems or can you give me indications about this issue?
Thanks in advance
