Print 3D
  • 1.  Print 3D
    Posted 08-21-2018 09:52
    Is there a way to share a 3D model in PDF format so that the individual looking at the pdf can rotate, zoom, etc.?
  • 2.  Re: Print 3D
    Posted 08-21-2018 15:10
    Yes, use the Create 3D PDF command. In the help, search for the topic called "Crete a 3D Portable Document File (.pdf)", which includes a link to launch the command.
  • 3.  Re: Print 3D
    Posted 08-28-2018 11:48
    Great work David ! That is for sure the right way to go here
    Don't forget that you could also share the VCE or an output VCL file of the entire project and they can use the entire model in the Core Version at no charge. You could give them a reduced Menu Ribbon with just those functions enabled that they need. You could also use the Preset Views function to create a set of View Filters that they can preview when they have the entire Project.
  • 4.  Re: Print 3D
    Posted 12-14-2019 11:32
    Curious if there is a step by step tutorial anywhere.
    Thanks for any info
  • 5.  Re: Print 3D
    Posted 12-16-2019 11:54
    Sorted. Updated to 5.20  .....
