Cut Fill Isopach Plotting Issue
  • 1.  Cut Fill Isopach Plotting Issue
    Posted 05-29-2019 09:16
      |   view attached
    My colleague and I have had constant issues with plotting isopach cut fill maps. When we print the plot box only parts of the isopach actually show up. It's a hit and miss whether it will plot properly (every 10+ tries we will get one that properly prints) Has anyone had this issue and how did you fix it?
    Attachment(s)
    pdf
    Plotting issue.pdf   80 KB 1 version
  • 2.  Re: Cut Fill Isopach Plotting Issue
    Posted 05-29-2019 16:16
    We believe that this is a "Memory Problem" and is best solved using the Sheet Layout Workflow - even if you just use the Simple Drafting Templates that I have posted on the forum recently, that workflow will give better / higher quality results every time and you will not see this issue that you see with the Plot Box and Print Preview / Print Process. The Sheet Layout Process also gives you the ability to add Title Boxes, Company Logos etc fully automatically and it is just as quick if not quicker to generate the Sheet Output on a PDF File.
    If you want to share your / a project with me I can take a look and see if it is doing the same thing on my Laptop as well, however we have seen this before and it appears to be hardware dependent more than TBC specifically related - if we can address the issue we will, but the Sheet Layout Process is the way to go from my perspective - other users that have followed this suggestion are all happy with the Sheet Layout Process - especially if they use the simple Drafting Templates approach.
    Here is the link to the post I made previously
    Click Here
  • 3.  Re: Cut Fill Isopach Plotting Issue
    Posted 05-30-2019 07:30
    Brittany - we've experienced the same issue when using the Create Plot Box command as well. We even had the same issue with a beastly workstation souped up for photogrammetry processing. As Alan mentions, you'll need to use the Sheet Layout Workflow to avoid the issue. We haven't had the problem since switching.
  • 4.  Re: Cut Fill Isopach Plotting Issue
    Posted 05-30-2019 07:41
    Thank you Alan and Richard. We will give that a try.
    Regards,
    Brittany Koebel, E.I.T.
    Project Coordinator
    C: (780)-235-6509
    8404 McIntyre Road | Edmonton, AB T6E 6V3
    <grahambuilds.com>     <linkedin.com/company/622180%3ftrk=tyah>    <twitter.com/grahambuilds>    <youtube.com/user/GrahamGroupLtd>
