When I try to load a .dwg file into TBC 5.00 I get prompted with an unexpected error. This happens if I try to drag and drop or use the import command. Using TBC 4.xx I never had any issues, and the file I'm trying to load was one that worked in 4.xx
Has anyone else experienced this issue? If so, any help would be greatly appreciated!
