Hi all. See the attached screenshot taken of the feature lines I processed in TBC. I have searched for a long time looking for where I can TURN OFF these small blue text displays of the point elevations. I cannot find any settings that will allow me to switch these blue numbers OFF. My thanks and appreciation to anyone that can show me where to make that happen inside TBC. Thank you !
Thank you Boris for answering this for me on LinkedIn !
It took me forever to find as well, but it resides under the options "gear" at the very top of TBC. Then go into the "View" folder in the tree on the left hand side. Once that expands, highlight "Display Options". The options on the right is where you can show or hide those numbers.
Also, minimize the amount of "Marker Line Object to Display". ? How do you choose which ones will display?
Francisco, you can choose what to show within the different areas, as shown above. You just have to pick which ones are show or hide. If you talking about how to toggle the "marker lines" on & off, that button is at the bottom of TBC.
