Hey Jesse,
I apologize for the delay, I've been on PTO the last week and just getting back to the community today.
As far as the direct export to GE, I don't think there are any user defined options at this time outside of what you've mentioned.
You can however export a shapefile under the GIS exports with the user defined options you're looking for.
Drag and drop the resulting .shp file into GE and select yes to create a style template.
Under the Name tab select the drop down next to "set name field" and change to Name and select OK.
The file is imported into the project with the user defined settings. You can then save the resulting imported data to a KMZ or KML if needed.
Let me know if this is what you're looking for or if you have any other questions.
Regards,
Shane Lyons
Shane Lyons
