You are welcome. Yes as long as ST was setup as the "Line control code" to
start a new "joining sequence"in your fxl file. It will also start a new
line if your line code is stepped up a value. For example if you go along
bl st, bl, bl,bl and then bl1, bl1 it starts a new line. That is easy to
use in the "measure codes" screen on your controller where if you have bl
programmed into one of the squares on your "measure codes" window and then
with it highlighted to hit the + button and it will step it up one value.
To program a code into a button or square tap and hold the square and then
select the code you want assigned to that square. The find feature is handy
as well. If you are doing a big topo and can't remember what the last
number you used for your bl (BreakLine) code you just highlight the square
and hit find and it steps it up to the first unused number. Also there is
a window at the bottom of the "measure codes screen where you can create a
code to use temporarily. So if you have Bl programmed into one button and
ST and End into other buttons or squares you hit the small button that says
code, things turn yellow and you pick for example bl and then st and it
creates in the window bl st. Hit measure and that code is recorded as your
feature code. To get out of it you hit the code button and things change
from yellow to normal and you can pick bl to continue your line joining
sequence. Hopefully I explained this fairly clearly. it is unfortunate
how there really are no help files that explain this process. Take care
and have fun. Access is powerful stuff. Everytime I had to use a different
system with a different employer I felt, "hobbled".
On Thu, Mar 12, 2020 at 8:34 AM jody.savage@morgansindall.com <
