Points to Surface Results
  • 1.  Points to Surface Results
    Posted 10-11-2018 12:16
      |   view attached
    Points to Surface Results - Request
    I have 24 pages of topo points shots and I'm searching for each point to look for anything over 0.10ft tolerance up/down.
    It would be very helpful and save us a lot of time if we can set criteria or tolerance and be able to color code, separate or group the report in a manner consistent to the criteria sets.
    Please see attach report.
    Attachment(s)
  • 2.  Re: Points to Surface Results
    Posted 10-12-2018 06:39
    Run the Pavement Conformance Report not the Surface to Points Report it does exactly what you want - you can set High and Low Tolerances and it flags points High Low or In Tolerance and will give you a Pie Chart at the top also that shows the Statistics of the Report
  • 3.  Re: Points to Surface Results
    Posted 10-15-2018 10:37
    Thanks Alan.
    I hope Trimble would be able to improve the points to surface reports soon.
    Pavement conformance report is good but you have to have an alignment which is not too hard to do for us but not for the engineers in the field that hardly use the TBC.
