Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and no p
  • 1.  Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and no p
    Posted 11-21-2018 07:24
    Print Plan Set
  • 2.  Re: Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and
    Posted 11-21-2018 07:26
    Seems like my question got cut off.
    Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and no pdf gets printed.
  • 3.  Re: Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and
    Posted 11-21-2018 18:41
    I see that you are writing the PDF to a Drive called X: (assume that that is a Network drive) maybe that is the issue if you try saving to Desktop or somewhere on your C Drive rather than the Network Drive - does it work then?
    It should not be the issue but that is the only obvious thing that stands out here based on a screen shot - failing that post the file uup here as a Zip File and I can take a look after the Thanksgiving Break
  • 4.  Re: Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and
    Posted 11-22-2018 21:02
    Alan,
    Writing the PDF to my desktop solved the problem. Thanks for your help and quick response.
    Pablo
  • 5.  Re: Could there be a reason why the Plan Set is not printing? After following all the steps shown on Alan's "Data Presentation" video, I get to the "Print Plan Set" window , click "Ok", then seems like the pdf is being generated but the window closes and
    Posted 11-22-2018 21:52
    Thanks for reporting the issue - I will try to find out why that would stop you from Printing - Glad I could help and get you going - I use that command all the time so I could not see any reason why it would not work until I saw the X: in your screen grab - that is the only thing that I dont do so it flagged it to me - sounds like it may either be a defect or that you dont have write permissions to your Network Drive - I will find out which next week when everyone is back in office
