PDF Drawing Scale
  • 1.  PDF Drawing Scale
    Posted 08-21-2018 09:48
    When importing PDF drawings, i have run across drawings that do not have dimensions on them only a scale as in 1:50
    Is there a way to set a scale on a pdf file without measuring the drawing  with a know distance?
  • 2.  Re: PDF Drawing Scale
    Posted 08-21-2018 21:12
    John,
    I have run into this may times. If I am working on a commercial site, I will scale along the parking stalls to verify the scale of the plan. If I am working on a subdivision, I will use the dimensions given on the details to scale BOC -BOC on the plan view.
    Mike Tartaglia
  • 3.  Re: PDF Drawing Scale
    Posted 08-28-2018 09:50
    John
    On the two examples you provided to me at PUG 2018 last week - With the current product if you have no distances to go on and just have the scale - here are some things that you can try
    If you open the PDF files in Acrobat Reader and go to File - Properties - you can see the Sheet Size that these are plotted onto (24" x 36") paper size.
    When you import the PDF into BC-HCE and you start the placement of the image, you can likely assume that the sheet border (highlighted line of the image) is the 24x36" border and use that to scale the plans if you have nothing else to go on. In this case the Scale says 1" = 20' so a 36" side of the plans is 720' so I use Known Distance and optional bearing if you want to orient the sheet to true north, enter the known distance of 720' and pick the Lower Left and Lower Right corners of the sheet. For the Bearing I would pick the South and North End of the North Arrow and it would rotate the sheet by ~90 degrees. Once the image is placed - I would check a distance e.g. between parking stripes and see what that tells me - in this case it is 9' which is the min spacing for car parking spaces - so looks OK so far.
    Note that in C4 there is also a Grid and you may assume that it is a 20' Grid because the scale is 1"=20' but actually if the Sheet Size scaling is correct the Grid is actually a 15' Grid (Go Figure ....)
    When I try Sheet C6, there are 3 drawings here all at 1" = 40'. If I use that sheet and scale of the profile Drawing where the Station indicators give me 100', 200', 300', 400' locations - I can use these to scale this drawing - then if I check the Parking Stripes on the Plan Sheet it shows them also to be 9' wide - confirming Sheet C4 scale to be correct.
    If I know these sheets go together, then I would likely use C6 first and then place C4 over C6 using points in C6 to Georeference the Plan part showing the Parking lot to the same plan part in C6.
    I will check more Sheets from other PDF files, but I believe that if you can read the Sheet Size from Acrobat Reader, you can scale the Sheets using the Sheet Size defined in the PDF file directly (just take the Scale data and the Sheet Size and compute the Long Side of the Sheet to scale - and then check something that you know to be True (like the Parking Bay width) to validate the scale to be correct.
    BE AWARE OF HALF SCALE DRAWINGS ,,,,
    Hope that this helps - I have asked Product Managers to look at the option to define a Known Scale and look at the Sheet Size in the PDF records to see if we could just put in a scale to scale the plans directly.
    This however is a reasonable work around I think.
  • 4.  Re: PDF Drawing Scale
    Posted 08-28-2018 10:05
    I tested this on a couple of other projects and it seems to work provided you watch for the Half Scale Plot issue - The sheet size in inches x the Scale Ft value (optionally x2 for Half Scale) gives you a scale distance you can use to place the sheet - this appears to be reasonably reliable.
  • 5.  Re: PDF Drawing Scale
    Posted 08-28-2018 10:12
      |   view attached
    Mr. Alan,
    Thank you so much I had not though to work the pages as you described.
    Means a lot to me that you looked into this and responded.
    I really enjoyed the training and look forward to the next one.
    Hope you have a great rest of the week!
    If you have any questions or concerns please contact me.
    Respectfully,
    John Curry
    Member/Manager
    JC Construction, LLC
    P.O. Box 1015
    Broussard, LA. 70518
    BUS:        337-256-5807
    FAX:        337-256-5674
    CELL:       337-551-2079
    EMAIL:   jcurry@jc-con.com<mailto:jcurry@jc-con.com>
    WEB:       www.jc-con.com<http://www.jc-con.com/>
    FB             https://www.facebook.com/JCConstructionLLC
    This email message is for the sole use of the intended recipient(s) and may contain confidential and privileged information of JC Construction, LLC. Any unauthorized use or disclosure is prohibited. If you are not the intended recipient, please contact the sender by reply email and delete and destroy all copies of the original message inclusive of any attachments.
