Yes I understand that. I set up my linework codes in the Trimble Feature Definition Manager so that when I use a code that is recognized as a line, it begins drawing without the use of a start command. My lines work as in my example above.
When I want to stop a line, I use the stop command and it works perfectly. When I use the same code again it starts a new line without issue.
My thought is when using the Close command as shown below, it should END a line, just like an end command does, in addition to connecting the last point to the first. The definition of the command even states that it's to be used when a line ends. Civil 3D, Carlson and any program to reduce survey data, ends lines when a close command is used.
Instead after using the Close Line command, it continues drawing the line unless you use an End Line command in addition to the Close Line command.
In my example above for point number 103 I have to use the code "BC + BC !" (Which is BC Close and BC Stop)
I really appreciate your time helping with this,
Damian
