Several commands have the ability to do this when creating objects. For example when creating nodes, if you name the first one MH-1, then the program will suggest MH-2 for the second one.
There is not a command that will create text objects and increment the name. This sounds like a good command to create in TML.
Can you provide an example of how you would use the incrementing?
tim
