Is anyone experiencing TBC Edit Linestring Command Issues?
  • 1.  Is anyone experiencing TBC Edit Linestring Command Issues?
    Posted 08-26-2020 09:32
      |   view attached
    Version 5.31, Vertical nodes are showing up unexpectedly!?  Sometimes Elevation values show in plan view and sometimes not.  Without Toggle Line Marking on, nodes will be visible.  When actively editing Linestring vertical node values are not visible.  Other weird things that I have not put my finger on yet when Editting Linestrings!?  All I can figure to do is go back to 5.3?
    See attached, Toggle line marking off and you can see Line markings on non sellected line as well as verticals on Edited Line in 3D view however not visible in Plan view
  • 2.  Re: Is anyone experiencing TBC Edit Linestring Command Issues?
    Posted 08-26-2020 10:31
    see this post it is the same thing you are seeing
    VER 5.31 DISPLAY COMPLICATIONS
  • 3.  Re: Is anyone experiencing TBC Edit Linestring Command Issues?
    Posted 08-26-2020 10:51
    Hi Nathan,
    Fixes for these graphics issues will be in the upcoming 5.32 release. The team is working to get it out to you as quickly as they can. Apologies for the inconvenience.
    David
  • 4.  Re: Is anyone experiencing TBC Edit Linestring Command Issues?
    Posted 08-26-2020 11:33
    If you Toggle Line Markings On then Off again that should update the Graphics. If that fails to work then open a New Plan View and Close the Old Plan View - That will clear any graphics issues. The team is working on getting this fixed.
