Is there a way to influence the import of DGN/DXF/DWG files into a TBC project in such way
that I will define the specific layer and its colour in which will appear the data from the source (DGN/DXF/DWG)
in a TBC project?
I mean – is there a possibility to change original layer and original colour for new ones in the TBC project before importing
using some kind of conversion table or so?
Example:
Let say that some data in a source DGN/DXF/DWG file are in Layer 1 in red colour, another data are in Layer 2 in green colour. When I import the source DGN/DWG/DXF file, in the TBC are the data in the same layers with the same colour like original source.
I would need to change it – for example – in such way that the original data contained in the Layer 1 in red colour would be placed in the TBC onto the Layer 20 in yellow colour, the data in Layer 2 in green colour from original source would be placed on Layer 30 in black colour in TBC, etc.
