Is there a good way to lengthen a line in Trimble Business Center?. My current workflow to add Feet to a line is to draw a circle at the end of the line with a 5' radius, Use Extend Command, Delete Circle. This process seems ok for 1 line, but if I have multiple lines, it's a bit time-consuming.
