@Ariel Silva
Hi Ariel, thank you for the file. Here's how you can bring the scan back.
1. Drag and drop the job file to TBC, ignore the import error.
2. From Project Explorer -> Imported Files, change the raw instrument height of the station to the correct number.
3. Expand the Backbearing node, change the "Use for" from Horizontal only to Horizontal and vertical.
4. Compute the project. Now the station should have an elevation to start with.
Let me know if this works for you. Thank you.
Rui
