adjust current.csd
  • 1.  adjust current.csd
    Posted 06-19-2020 00:54
    I created a new geoid model (.GGF file).
    if I understood correctly, to be able to use it when I import a JXL file in TBC I have to add it in the coordinate system manager.
    When I add a new geoid model and select the one I used. I cannot save the .CSD file. (I always get the error "failed to save document").
    Kind regards,
    Sebastiaan
  • 2.  Re: adjust current.csd
    Posted 06-22-2020 15:21
    Hi Sebastiaan, here is a trick I learned from our engineer Nathan, hope it helps.
    I suspect an older (or another) Trimble application changed the GeoData location. Some older applications save it to C:\Program Files (x86)\Common Files\Trimble which is not desirable without respecting what may have been installed already. CSM does re-use any existing GeoData if it is installed after.
    The easiest way to fix this is to run the Cleanup Utility, select the following options and then click Run.
    When it has been removed, you can re-install the standalone CSM (download link: http://dl.trimble.com/osg/survey/csm/3.7.3.0/x64/csm_setup.exe ). It may break the older apps. To workaround this, run the Cleaner from the Quick tab, install the older apps first and then install TBC.
