5.30 Bug? explode command
  • 1.  5.30 Bug? explode command
    Posted 05-20-2020 04:13
    5.30 Bug? explode command gives error on Cad block
  • 2.  Re: 5.30 Bug? explode command
    Posted 05-20-2020 07:25
    Ben
    I just checked a CAD file here and cannot recreate this issue - can you send over the Blocks that you were exploding in a VCL file so I can just try on the ones that you had issues with
  • 3.  Re: 5.30 Bug? explode command
    Posted 05-22-2020 05:43
    sent to your rockpile email
  • 4.  Re: 5.30 Bug? explode command
    Posted 05-22-2020 08:14
    I get this from time to time also. Usually I pick fewer blocks to explode and it works.
  • 5.  Re: 5.30 Bug? explode command
    Posted 05-22-2020 08:39
    that is not the case here
