Bug V5.3 clip command taking forever
  • 1.  Bug V5.3 clip command taking forever
    Posted 04-30-2020 09:49
    trying to clip lines outside and selecting 6586 lines and it has been running for 30 minutes and still not done yet anyone else having this problem?
  • 2.  Re: Bug V5.3 clip command taking forever
    Posted 04-30-2020 10:41
    was able to clip this same DWG file imported into Busines Center in autocad in seconds
  • 3.  Re: Bug V5.3 clip command taking forever
    Posted 04-30-2020 18:57
    Can you share the project - probably a data issue - maybe some ucs objects?
    Let me take a look
  • 4.  Re: Bug V5.3 clip command taking forever
    Posted 05-09-2020 09:55
    We found a defect that has been recfified - if you leave it long enough it does finish but with the change it does this quickly - thanks for the data and raising the issue
  • 5.  Re: Bug V5.3 clip command taking forever
    Posted 05-29-2020 05:15
    This is a major bug and should have been patched buy now.
