Protect points in use
  • 1.  Protect points in use
    Posted 08-19-2020 06:43
    Is there a way to protect points in use from being deleted like we had in Terramodel?
  • 2.  Re: Protect points in use
    Posted 08-19-2020 06:55
    If they are on a layer then you can make the layer unselectable in the Advanced View Filter Settings. There is nothing else that stops a point from being selected and deleted in TBC today that I am aware of. There is a Lock function on points with feature code processing that stops points from being reprocessed each time you run Feature Code Processing.
    Something triggered you to ask this question - what was that?
  • 3.  Re: Protect points in use
    Posted 08-19-2020 09:15
    yes, I was working with cad data and was cleaning up the existing field shot layers and the points were on a few different layers, hundreds of points with a lot of other unneeded stuff on the same layer (points were used in a surface), used the selection explorer after selecting by layers to get what i needed to delete and was thinking how much easier it would have been if protect points in use was an option just select all on the layers and delete but the points would still be there protected. also have deleted points in use before not paying attention by selecting by layer.
