Third party GNSS antenna identification
  • 1.  Third party GNSS antenna identification
    Posted 08-01-2019 17:54
    Does anyone know how to define GNSS antenna in TBC?
    Is file Antenna.ini to be modified ?
    I want to do is identify the antenna model when I import the rinex file of the leica GNSS
  • 2.  Re: Third party GNSS antenna identification
    Posted 08-05-2019 14:44
    Hi Junning,
    TBC's antenna files have included quite some 3rd-party receiver/antenna types as you may see from the screenshot below. Could you check if the required type is in the list already? Make sure your antenna model points to Automatic, so all available antenna models will be in the pool.
    We don't recommend modifying the antenna files manually, as TBC may not understand that model and handles the parameters in an unpredicted way.
    Thank you.
    Rui
  • 3.  Re: Third party GNSS antenna identification
    Posted 08-05-2019 20:56
    The old version of TBC needs to update the antenna file.
    Fantastic~
    Thanks~
