Is the Trimble Geoid18.ggf file okay to use given the errors recently found?
  • 1.  Is the Trimble Geoid18.ggf file okay to use given the errors recently found?
    Posted 12-18-2019 02:54
    NGS has found errors in the new Geoid18 model. Is the Trimble ggf file safe to use?
  • 2.  Re: Is the Trimble Geoid18.ggf file okay to use given the errors recently found?
    Posted 12-18-2019 10:06
    Hi Joshua,
    The errors in NGS's provided geoid files have been addressed with the release of the Coordinate System Database 88. The full announcement post can be found here: **GEOID18 Update in CSD88** .
    This database can be downloaded through the 'Check for Updates' command in TBC.
    -Josh
  • 3.  Re: Is the Trimble Geoid18.ggf file okay to use given the errors recently found?
    Posted 12-18-2019 10:14
    What about the .ggf file that goes in the data collectors. Has that been updated?
  • 4.  Re: Is the Trimble Geoid18.ggf file okay to use given the errors recently found?
    Posted 12-19-2019 09:47
    The files on the data collectors also outdated and will need to be updated to CSD 88. All Trimble programs use the same files for coordinate system files (C:\Program Data\Trimble\GeoData).
    I would recommend updating the coordinate system database on your tablet as well by using Check for Updates in the Coordinate System Manager.
    -Josh
