Is there an equivalent command to TerraModel's volume from contours? If not, what is the best way to get incremental areas and volumes between contours? Any help would be appreciated. Thanks
When you run the Surface to Surface Volumes (Earthworks Report) you can select Volumes by Depth Increment or by Elevation Interval - if you choose by Elevation Interval this is basically the same as using Contours in Terramodel - the report will show the volumes of each contour slice between the surfaces.
Perfect ... thanks Alan!
Grant Runyon, PE, PLS, CPESC
