-Right click on linestring grip to add/remove vertices (with ability to shift select multiples).
-Make Macro commands available for right click "recent commands" use.
-Allow Layer Manager columns widths to be adjusted.
-Allow Esc key to always exit out of command/deselect objects. Seem like this was the case in earlier versions.
-Have Remove Segments macro remain active on same line.
Thank you!
