Name Linestring From Point?
  • 1.  Name Linestring From Point?
    Posted 01-12-2020 19:13
     Is it possible to name linestrings by near points? Many times I get Civil 3D files with feature lines all on the same layer (Ex. "C-TOPO-FINISH") and with no name. Other times I can extract surface breaklines but with unhelpful naming such as "breakline set1234". Either way I end up with linstrings all on the same layer with no easy was to separate them and layer appropriately. I can usually export points with TC,TP, FG, ect. naming and was wondering if I could use near points names to name the linestrings in TBC. Or if anyone has any ideas on to separate them Civil 3D that'd be great too.
    Thank you,
    P.S. Files with corridors allow me to extract links separate so I layer them appropriately before importing to TBC aka (TOC, TP ect) but that's no help here.
