Surface boundary issue - zero volume
  • 1.  Surface boundary issue - zero volume
    Posted 10-24-2019 01:17
      |   view attached
    I have seen a recent post with a similar issue to this, but am wondering if there is an improved workflow that might help avoid this happening in the first place...
    When trying to calculate a surface to surface volume constrained to a boundary, I am getting zero volume, and zero triangulated area.  When I make a duplicate of the boundary, and re-attempt the exercise, I get normal volume and triangulated area reported.
    What is causing the error in the first boundary, and is there a way to easily avoid this (noting previous comments suggesting a small horizontal offset... while this does appear to work, it is not ideal in all cases - and for very large boundaries, even a small offset can result in a change in area that leaves work open to scrutiny).
    I have attached an extract of the project file in question.  Calculating volumes from surface "Made Ground" to surface "FGL-450mm Oct19".  The problem occurs when using boundary on layer "SiteDBoundary" (Problem Boundary), but is ok when using boundary on layer "SiteDBoundary-COPY" (Copy Boundary).
    Appreciate your thoughts / insight - many thanks in advance.
    Attachment(s)
    zip
    ProblemBoundary.zip   8.61 MB 1 version
