I'm having an issue of adding entities on an existing selection set.
I have created a new Utilities as-built selection set and added the initial lineworks fine. But when I start adding a plotbox and point labels onto the set I just created, it doesn't add it. I had all my layers turned on on the active Filter and the number of objects under the selection set remains the same even after I add new objects in it. Therefore that just tells me that it's not successfully adding it.
Does anybody else have this issue with Version 5.0?
