The text can be placed anywhere including in the Title Block. The challenge
is that you may have several Dynaviews on a sheet and they can all be at
different scales - the smart text retrieves its Scale values from the
Dynaview to which it is referenced. Also because the Dynaview does not pre
exist in a Drawing Sheet, you cannot set up that reference so that it is
automatically filled in - you have to change the reference to the Dynaview
on each sheet that you create - for that reason I typically do not use the
Smart Text Item for Scale - I manually update it from a default value (eg
1' : 50') rather than auto extract it as the editing of the text takes the
same amount of time as re referencing the smart text to the correct
Dynaview - and in many cases my default scale will be correct and I dont
have to change anything. Using the Smart Text does eliminate any possible
mistaken scales of course and from a QA standpoint that may desirable.
On Sun, Mar 31, 2019 at 6:05 PM efgeorge@gmail.com <trimble@jiveon.com>
