Our project is a 10 km road upgrade, including rail sections, side roads and Cain rail relocation.
We are in the early stages and have already 41 designs on Worksmanager, which currently are used by 9 x GCS900, 2 x Earthworks and 6 x Siteworks systems.
We are using Worksmanager only and Publish everything from TBC. Our goal was to just publish it once and be done, but unfortunately the system doesn't live up to our expectations yet.
The first hurdle here is that TBC won't show you existing designs from Worksmanager to choose from and create a new version with new data. Right now you always have to use the original TBC project for that, which is a mess. If we get a new revision from the designers we want to import it into a fresh project in order not to mix old and new data. We then would like to create a new design version (same name but incremented Version number) on Worksmanager out of this new TBC project, not possible. We have to work around this by exporting a VCL from the new TBC project, import it into an upload project, create the new version on Worksmanager, delete the VCL from the Upload project. An absolute crap.
You can't manually create a design on Worksmanager for machine and tablet at the same time using the same name.
You can't push designs specifically just to certain devices. The machines on the northern end don't need the models from 10 km away. (I could start playing around with multiple projects and separate geo fences now that we can load a DXF for those. But that's not an option since the Siteworks systems for the Supervisors are used everywhere and they'd have to synchronize all the time.)
The VCL format on the new Earthworks is a nightmare. You'll have to actively break dependencies in the TBC project before publishing to Worksmanager. Otherwise everything you used to create that model ends up in the VCL and on the EW machine. I've seen models that are 800 kb for GCS900 but 65 MB on the EW machine. Ridiculous.
With all our models on the EW machine the idle circle is on the screen literally for minutes (I've stopped it and have a video) before you can choose something in the project menu.
EW seems to not support all VCL data. We have models that completely crash EW.
And we've seen the following errors.
the model will not load and it can't be used
the model will actually load and can be used
I've reached out to our local SITECH and they have forwarded it to Trimble but it's already 2 weeks now and I haven't heard back yet.
Luckily we only have 2 EW machines on site now since I had to set both to manual USB synch for now, and we bring designs one by one. But still, our goal was to never have to drive with a USB stick to a machine again. So far that is a fail.
We have absolutely no problems with GCS900 and Siteworks. GCS900 gets nice small SVL/SVD data packages as always and our Panasonic FZ-M1 for Siteworks cope well even with the largest VCL files.
There is one drawback with VCL on Siteworks though. If you publish a design as "Road surface" it won't show you a cross section view. If you create it the old way in TBC and upload the .pro file it will show you the cross section.
new Worksmanager .VCL format
old school .pro design
