Vertical Design tool broken 5.3?
  • 1.  Vertical Design tool broken 5.3?
    Posted 06-16-2020 12:58
    Vertical Design, anyone having issues with this since the release of 5.3?  It worked great in 5.2 but then something went wrong after the update.  Curious if I am the only one.  Thank you.
  • 2.  Re: Vertical Design tool broken 5.3?
    Posted 06-16-2020 13:51
    I have been using it this week - what are you seeing Thomas?
  • 3.  Re: Vertical Design tool broken 5.3?
    Posted 06-17-2020 05:36
    In the earlier version it worked just fine.  After the update as some of my models had to be rebuilt the rebuild method in Vertical Design edit seemed to break all of my instructions.  I eventually just deleted the Vertical Design and decided to rebuild it.  When doing this I could get an instruction to tie from my CL alignment to the EP but it wouldn't keep that instruction for the length of the line.  This happened on both sides of the roadway.  When creating another set of instructions for the gutter pan and top back of curb, these wouldn't work at all.  They flagged no errors, just didn't vertically adjust anything.  When viewed in 3d, those lines stayed in ? elevation.  They are all linestrings instead of polylines with the obvious exception of the road centerline.  I am not sure if I am doing something wrong or if something broke with the tool.  Maybe the file itself has become corrupted?  I eventually abandoned the Vertical Design tool and built corridors.  https://1drv.ms/u/s!Atgw1bevi0UX4wxN5QOADFDSMeq2?e=jhWQAq
    Here is a link to my file if you have time to take a look.
    Thank you!
  • 4.  Re: Vertical Design tool broken 5.3?
    Posted 06-18-2020 11:17
    I have stopped using the feature until it matures a bit more. The feature has so much potential but it's just a bit frustration to use at the moment.  I just revisited a project that I had VD elements, and several of the rules, which were fine when previously saved and closed, were now "broken". I'm not sure of the timeline related to 5.2 to 5.3 though.
