Project Saving Location
  • 1.  Project Saving Location
    Posted 01-07-2020 09:25
    I have been working with two project recently that have been saving different from all of my other projects. I have found that the management folder or the Project icon are saving in a different location the Download and import folder. Now most of my project just create subfolders in the same location on my desktop in a TBC folder. These two project have been saving the project it self in the folder but put the Downloads and import Folder in a different location on my hard drive. Some reason there two project wont let my check the box to use project subfolders. As you can see in my screenshots. My problem is when I go to transfer the job from the office desktop to a field laptop I no longer can just Zip up the two VCE files  and the file folder together and share it.
  • 2.  Re: Project Saving Location
    Posted 01-08-2020 03:56
    What you're looking at there is a software options menu not a project specific menu.
    Have you updated the software mid project?
    My suggestion would be open up TBC without a project, just run the base program to get the spash screen as below
    It looks like you originally had the location set at C:\Users\GPS.SLS\Desktop\
    So set that back to the project management folder, open and resave your project and that should, hopefully, solve the problem.
    You might have to copy some of the intermediate data from the documents folder back to the new folder on the desktop.
