Is there a way to set a default layer for corridor templates? When creating a corridor template there is no prompt to choose which layer the user wants the template to go to. I would like to see an option in: Project Settings/Computations/Corridors that would allow the user to set the default layer that templates are created on. Putting this in the project settings would not bog them down with with selecting a layer when creating a template. Setting a default layer would help keep good data off of the 0 layer.
Thank you.
