The big issue is moving a node/pipe run/pipe from an existing network to another existing network. There is not way of doing it.
i.e.
I have 2 existing networks; drainage and sewer. Both with data in them. I accidentally created 8 sewer manholes in my drainage network. I want to move those sewer manholes from the drainage network to the sewer network.
You have to:
- Delete the data from the old network
- Create create the data in the new network
Depending on the amount of data, this could be quick or this could be quite cumbersome.
