I am running into issues with running the identify site region on a sidewalk area. I am not sure why. Everything appears to be setup correctly. One of my theories is maybe it is because of the arc.
I checked:
- to make sure that I did not have overlapping linestring.
- Gaps were reasonable
- gap tolerance in Project Settings/Computations/Takeoff
- I have this set at .05 currently but I also tried .15 with no difference to the area in question
It will work if you elevate the line but I do not always elevate my takeoff lines, especially in this case because I used a corridor to 3D model this portion. I will now run the risk of having to update this line if the corridor updates.
I could use a drape line elevating it based on the finished design surface but I feel like this is kind of eerie because you are creating a reference within a reference to form the end goal. Loop de loops. It is kind of like a nested IF statement in coding. It can work but it can also mess you up.
Use view "Takeoff".
Thank you!
Locus Map:
Problem Area:
Working with line elevated:
